Pyronix enforcer
15 Jun 2022
Hi, I have this system and was working fine until I press a wrong button in the engineers program my fault entirely. It's still works 90% but I need to reinstall. Do I have to do an engineers reset? Do the pirs reset on their own?
Thanks for taking the time
17 Jul 2018
Just change the setting back that you changed in error
What is the actual problem you have?
15 Jun 2022
Difficult to explain. The system sets ok and upsets. I have a and b set up. A is full b is downstairs. When b is set from the fob It doest work correctly, plus its connected the the phone line which doesn't alert me any more. I seem to have 2 pirs called the same and can't identify the wrong one.
Appreciate your lightning reply.
15 Jun 2022
When I say b doesn't work , the alarm triggers when the pir detects me although it's. Set as an exit route
17 Jul 2018
Was everything working before you changed something in error? You can fully reset the system settings either deleting or keeping the PIRs attached to the panel or alternatively we can try and resolve step by step.
15 Jun 2022
working 100% before i changed something.
What does it reset? I do need to get rid of the bogus PIR
17 Jul 2018
Doing a full reset seems overkill.
Can you go into change inputs on the engineer mode and put the info of each logged input into a reply here
Also go into site options > exit modes and post what the exit mode is set as for A and B
17 Jul 2020
W.yorks
Which pir sets the alarm off? The first one that sees you on entry needs to be set as final exit. This would normally be the door contact, or hall pir if no dc. Entry route zones trigger full alarm if activated before the final exit zone.
17 Jul 2020
W.yorks
If using a door contact the pir at bottom of stairs would need to be ER (Area FX)
15 Jun 2022
Thanks , I can't sort for a couple of days but will come back to you
15 Jun 2022
There is a door contact on the external door, but the hall pir sets the alarm off when it sees me. Should this be final exit? All others enrolled to the control panel are exit routes?
17 Jul 2020
W.yorks
Door contact final exit. Hall pir ER (area FX) . This makes it a final exit in area B to start entry timer when you come downstairs, but entry route in area A. All others should be intruder if not on any entry routes
15 Jun 2022
This is what I have
01 Door 07 Final Exit ABC (FRONT DOOR)
02 Hall 09 ER (areaFX) AB (EXIT TO FRON DOOR AND 1ST WHEN COMING DOWNSTAIRS
03 Study 06 Intruder AB ( SEPERATE ROOM DOWNSTAIRS )
04 Dining 08 Entry AB ( FAMILY KITCHEN DINER WALK THROUGH TO GET TO cp )
05 Lounge 06 Intruder AB ( SEPERATE ROOM )
06 Landing 06 Intruder A ( UPSTAIRS )
07 Utility 08 Entry AB ( LOCATION OR CONTROL PANEL )
08 Landing 06 Intruder AB ( AS ABOVE )
09 Garage 06 Intruder ABC ( SEPERATE BUILDING )
10 Back Bed 06 Intruder A (SEPERATE ROOM )
I DO HAVE 10 INPUTS NOT SURE WHY I HAVE 2 WITH THE SAME NAME
When I use the fob with 1 and 2 on ( A and B ) I set B and it beeps rapidly then a long tone. When I come down stairs nothing happens.
Do I need to reprog the fob?
15 Jun 2022
On the exit modes I have
A Timed Final [2]
A PTS [3]
A Times [0]
A Final door [1]
