pyronix euro mini alarm activated
31 Oct 2005
HI,
I have a Pyronix euro mini panel and system.
When we go to bed we press YES and B.
Lastnight the alarm sounder activated about 4 hours after being armed and the only red led I saw on the screen was " zone B" flashing. It didnt accept the normal 4 digit code. We had to put in the engineers 6 digit code for the alarm to stop.
I couldnt see the tamper fault up or anything else and it looks all clear this morning.
The firm that set it up 5 years ago are no more.
Is there anyway this system leaves a history that can be viewed so we can see what might have caused the problem.
Thanks Neil
You shouldnt be able to turn off an alarm when set with an engineer code …. Is that code the master code ? If you press D then master code you can get to view the log
Thanks sparkym I’ve retrieved the details from this morning and it’s saying the kitchen sensor activated ( input ) . No idea why it wouldn’t let me accept the alarm with my normal 4 digit code .
Might change the sensor out anyway as the mrs needs the system working when I am away .
I ll open the sensor to see if it’s clean etc .
Thanks again sparkym
