Pyronix v9.53
Broadly it would be good just to get hands on the manual so I can see it page by page
But specifically, I don’t know the master managers code on the panel, from the engineers menu I was hoping to change it but it won’t let me...
Once I’ve put the new code in and push yes it just sits there and does nothing
Panel is running v9.53
Will I have to clean start the panel or should it let me change the master manager code from within the engineer menu?
Yes it should let you, try a 5 digit code, or try setting use 5 digit pins to no (when you first select change codes) and try the 4 digit code.
Also make sure the code you are trying to use is not in use by any other user or engineer code
Tried both mate...
Also tried toggling the 5 digit codes on and off and saving inbetween
