Query - Fixing heavy items to plasterboard
27 Sep 2011
I just fitted a semi pedestal basin to a plasterboard wall
In order to give the basin/fixing strength, I placed some wood (approximate size was 2 x 4) behind the plasterboard and screwed some long wood screws into this .
I then used a santary fixing kit to secure the basin to the plasterboard/wood
Will my basin be okay?
Normally, I would screw a noggin between the studs but this was not possible due to space restriction
Is there anything protecting the plaster board from becoming wet?
I personally would have used the noggin fixed to the studs. I'd not be happy with the plaster board taking the weight, even with the load spread out with some additional timber.
Yes, the plasterboard wall was tanked, tiled and grouted
Thanks for the comment
It'll be all right but shame you couldn't nog it or even stick a vertical in under your batten to transfer load to the sole plate.
