Hi Everybody.
I just want to check if the following comply with electrical safety regs. As all the work will need to be signed off.
I plan to mount 4 double socket outlets on to a piece of wood and daisy chain them together. These will be powered by a fused spur coming from a socket on the ring main. The board will then be mounted in the attic in an accessible location. ( i think this is ok so far?)
The possibly sticky bit!
I want to wire several wall lights and down lighters in. I was planning to wire these into a mains plugs with the correct fuse rating and then plug them into a remote controlled socket on the previously mention board.
I know there are other options for home automation but for reasons that i wont go into remote controlled sockets are the best option at the moment providing all this comply s with regualtions
