Just had the back half of my semi integral garage converted to be a home for the kids guinea pigs. The questions involve plumbing in a radiator in the new room which is directly below the bathroom in which I have access to the pipe work for an existing radiator which is 15mm. When we had the boiler redone last year the engineer said it was more than adequate to support an additional rad in the planned room.
1. When plumbing to the existing rad how can I tell flow and return, it has no TRV, is there a noticeable temp difference in the pipes as they enter the rad?
2. Do I tee into the existing flow and return pipes for the bathroom rad or do I pipe it to be inline with the existing rad? Ie link between the rads and use one flow and return line?
3. Do I need to wrap the pipe work in insulation as it goes through the cold part of the garage on its way to the new room?
4. How long do guinea pigs live for? When I can plan a better use for this room?
Thank you
Thank you
