Quick question (Senior moment)
29 Apr 2013
Carmarthenshire
I'm gathering all the bits n bobs ready to have a multi-fuel Rayburn installed & we're using a TELBCI18045VF - Telford INDIRECT Combination Cylinder 1800 x 450, single-coil, with immersion.
My question is.
Do I need to order a ball-valve for the cold water inlet at the top?
On the spec, there is no mention of the actual cold-feed so I assume a hole needs to be drilled and the feed installed. The coil in & return are clear as is the drain and hot water outlet but no mention of the cold feed or any overflow. I'll need to get everything in by the weekend as it's being fitted next week.
Thanks in advance.
