Hi chaps,
was asked to look at a faulty shower pump today, havn't really installed one myself so was a little confused. Pump was leaking from the main body and making a loud grunting sound.
this is the pump:
pump feeds a manual mixer shower. Hot water tank inside a storage room adjacent to the bathroom 1m above ground level, pump sits under the bath tub approximately 2m away from the hot water tank, direct hot water feed into one inlet of pump and cold mains pressure through the other inlet!!! I advised the chap that when he did the install, he wasn't meant to connect mains cold to the pump!!
Question is, can I connect the cold water feed direct to the shower and have just the hot water pumped?? This will mean that one side of the pump will have no connections, is this ok? It will mean equal pressures at the shower which is ideal.
Dan!!! Help....
cheers
this is the pump:
Dan!!! Help....
cheers
