- Joined
- 4 Mar 2008
- Messages
- 19
- Reaction score
- 0
- Country
First of all I would like to say Hi as I am new here, and secondly I have a question about a shower pump.
I am looking at getting this pump http://www.screwfix.com/prods/46231...-5bar?cm_re=SEARCHPROMO-_-SHOWER PUMP-_-46231
My question is that in the installation instructions it says your cold water storage tank has to be a minimum of 1.2m above the head of your hot water cylinder. Would this be ok with my set-up as my cold water tank is directly(30cm) above my hot water cylinder, I cant think of a reason it would need to be that much higher.
The pump will be used to feed a shower with cold from the cold water tank and hot from the cylinder, the reason I want to user a pump is that I will be installing a thermostatic shower and i'm guessing the pressure on the hot will not be there.
One thing to mention is that it will be replacing an electric shower so there is a mains coldwater feed in the bathroom(i'm pretty sure its mains and not from the tank) already would I be able to utilise this and have a single pump?
Any suggestions advice welcome.
Thanks in advance, Jon
