quote for French doors and 2side panel
12 May 2006
Bristol
Had some quotes for 2 french doors and 2 side panels. Total size 2700mm length and std size height. the end panels will have a cutout from base from brick/concrete anbd window sills placed on inside on either side.
had a quote for £1670 form gardinia windows. Looked at others but 400 was also added on top to dismantle attached wooden derelict porch and biiuld steps into garden.
Most quotes have been 1600-1800. Is this a fair price for french doors.
The doors and side panels are around 500 quid at Wickes.
depends on access to job how easy it is to do etc etc.
the question is do you think they are worth that much and do those companies fit stuff from wickes?
Most companies fit there own stuff cos they make it for nothing.
They will charge top labour rates and fit a product which is easy to make.
The job is not hard to access from lounge at all, quite spacious(wide area).
The problem is Wickes do not do a 2700cm width incl side panels...not sure or if anyone else knows if they do made to measure.
