Rad Brackets
8 Jul 2006
Lancashire
Hi All,
Just wondering - is there a prefered choice of which way round radiator brackets go ?
I am fitting a d/p single convector to the wall . Is it better for air circulation that the rad be away from the wall ? Wide support outwards ?
The rad data sheet does not say - and I have found different advice on manuf web sites.. maybe it does not matter if the manf don't mention it ?
What would you guys do please ? - I can move pipework if required.
Many thanks
Stoyer
If you have a window sill above then have it spaced off as much as you can.
I always use the wider fixing as standard and the closer on if needed if I am fitting to existing pipe work out of the floor.
