I have a cloakroom, (1.3m deep, 0.8m wide, 2.3m tall) and the heat calcs give a need of about 550BTU. It also has the boiler in this cloakroom wall mounted and I understand I may get about half of that heat radiated from the boiler.
So all I need in the way of heat input is about 250BTU. Even the smallest radiator or towel rail is double that but more important the area beside the toilet is so narrow the extra few inches elbow room taken by a rad will be noticeable.
I wondered if a length of 22mm copper pipe run floor to ceiling in one corner might give enough heat?
If something like this would work I guess it would need a valve in the pipe to control flow??
