Hi Kev.kevplumb said:how big is the rad![]()
Thanks Nicksonickso said:the pipes shouldnt be taking the weight in any case.
screw plywood onto the studs in several places and screw the rad onto the plywood...spreads the weight more to stop the wall falling apart
Thanks for answering Paul. Would you rather cut out a length of plasterboard between the two studs so that you can screw a noggin inbetween the studs and put the length of plasterboard you have cut out back on or would you not touch the plasterboard at all, try to locate the position of two studs instead, screw two lengths of noggin the same thickness as the studs through the plasterboard, through the studs, paint them the same colour as the wall and fix the rad brackets through them??Paul Barker said:nickso said:the pipes shouldnt be taking the weight in any case.
Yes this is the best suggestion, I have used all methods but this one lasts longest, short of plunging an oblong hole in the board, guiding a longer but same width noggin into it at, two screws to secure it's position, patch up, and fixing rad bracket through board to the noggin.
The problem is far greater in a tiled bathroom with a ladder rail. About the only reliable option, failing the above method followed by full retile, is toggle fittings, but the ladder rail will soon be swinging free. You have to fix rads and towel rails to withstand the bums of idiots who like to swing off them.
Many fit a bathroom suite in 3hrs newbuild site plumbers make a complete balls of drywall fixings, leaving us a few years down the line to refix it. If the build was prperly coordinated appropriate noggins could be designed in, but of course you can't make a fortune doing new builds properly.
