rad problem
10 Dec 2007
Hull
Right, in my bathroom, under the floorboards, there were 2 pipes that used to serve a rad in the room, i've finally got the bathroom finished and i've inatalled a rad in the bathroom, and one in the seperate wc. I've taken the H/W feed into the first rad, the joined the second rad in sequence. ( should i have done it this way, or should i have 'T'd' into the H/W to feed both rads at the same tim???)
The problem i have now is that the first rad takes ages to warm up, even then it's not getting anywhere near as hot as the other upstair radiators, and the second rad in the wc is not getting hot at all.
I've bled all the rads, i've isolated all the rads except for those 2 to try as push any airlock through, i'm now out of ideas!!
Any help would be appreciated
I've taken the H/W feed into the first rad, the joined the second rad in sequence. ( should i have done it this way...
Assuming for now that you mean "heating flow" rather than "H/W feed", then no, you shouldn't have done it like that.
Yes.
That's right. You've f*cked it up.
You know what you need to do.
Thanks for the reply, short quick and to the point!! :lol:
I'll have another go and post back!!
