- Joined
- 31 May 2007
- Messages
- 369
- Reaction score
- 0
- Country
Hi
I have a radiator that has developed a leak from where the wheel head side of the radiator connects to the valve. The valve is ok, I just need to change the part that goes into the radiator.
The valve is a thermostatic pegler terrier but was here from before i moved in, im guessing 80s. I have used the cap off another thermostatic radiator to shut the radiator off turning it clockwise.
My problem is, I closed the locksheild clockwise and the wheelhead but when im draining the rad from the airvalve water is coming out and the pressure of the system is dropping. So obviously the radiator is still getting water in.
I have tried both valves clockwise and anticlockwise and still its the same.
Does anyone know what can be causing this and how I make the changes i need to without draining the system, or if u no the valves are definitly faulty?
Thanks a lot and happy new year
