Radiator above double electrical socket
15 May 2005
Sussex
I am doing some changes to my house which means I need to move a rad from one side of the hall (currently under open stairs) to the other, the only trouble being there is an electrical double socket on that side right in the middle of the wall just above the skirting.
I could mount the rad slightly higher to clear the socket or I could look for a designer rad or similar which would not cause an issue.
Any one got any other thoughts/ideas. I think it would look odd with a normal rad that high up but I also want to keep the socket.
Many thanks
Neil
If you don't want move the socket then a vertical Rad would be the best option, don't put a normal Rad up high though, would look awful
Yeah thats what I was thinking, could use a radiator cover but not sure about those either.
Vertical rad had crossed my mind, I might just bite the bullet and move the socket.
A stupid question maybe but why dont you move the socket? On the assumption you have suspended floors then you will have to lift them to re-route the pipework to the radiator so you could move the socket along at the same time.
If you aren't fussed which way it goes you might even have enought cable to move it in one direction without adding a junction box. If not then a junction box (of the correct capacity) will allow you to extend the ring main easily.
I was trying to get away from chasing out the walls to move cables but I think thats the way I am going to go.
Thanks for your input. :-)
