Radiator balancing maybe?
17 Jan 2006
Derbyshire
Got a slightly confusing radiator problem. New rads have been fitted downstairs but the small bedroom one is causing problems. Each rad can heat up independently while all others are closed off and then by opening each other rad just a tiny bit lets them all heat up apart from the living room one. If the small bedroom one is completely off then the living room is too hot to touch but as soon as it's even slightly opened up the living room one goes cold. The boiler is a Baxi with the tank in the loft, there is no air left in the system and the water came out clear when drained to replace the downstairs rads. Any suggestions on what to try next please?
Sounds like a piping problem, . EG if your living room rad is piped off drops from the small bedroom one's tails, it would do exactly what you say.
You can get similar stupidities if you have blocked air or sludge. It might "get better" after a couple of days, as the air sorts itself out.
"Tiny bit" open could be something like 1/20th of a turn - its surprising how little can be needed. If that is the case, it'll never work reliably though.
