Hi All,
I am planning the new installation of radiators in my stone cottage (getting rid of the night storage heaters at last -yippee ). The cottage is only 4 metres wide and is like 2 railway carriages one on top the other; 3 rooms downstairs and 4 smaller ones upstairs - all in a straight line.
I plan to use one long 22mm feed and one 22mm return pipe from the boiler going in a straight horizontal line from one end of the cottage to the other - at floor level upstairs. The boiler (not selected yet but likely to be a Trianco or Worcester condensing oil boiler near the top end of the price range) will be downstairs teeing into the centre of the 22mm feed/return pipe-runs.
Rather than a circuit of radiators in series, I plan to tee each one (15mm) individually from/to the 22mm feed/return for both the upstairs and downstairs rads. Much like a fishbone I guess. (For reasons I won't bore you with, it will make life much easier this way).
My question is this: given this unorthodox layout, am I likely to have problems with balancing the radiators in due course, or any other unforeseen problems? If so, what would the experts suggest?
Thank you in anticipation.
'Rapide'
'Rapide'
