- Joined
- 20 May 2019
- Messages
- 13
- Reaction score
- 0
- Country
I have bought a new radiator for one of the rooms in my house but the closest match I could get size wise is 80mm wider than the original (wife wanted an oval tube rad to match ones in other rooms).
The issue I have is that the 10mm copper tails don't have enough movement in them to move 40mm each to the side - I have cut a horizontal slot in the plasterboard to either side of the pipe but there's just not enough flex to move them out far enough.
The pipes come directly out of the wall at about 50mm above the skirting board and then 90 degree elbow upwards into the bottom of the valve.
Would appreciate any suggestions on what I could do with the pipes - short of taking the skirting board off and knocking holes in the wall.
Cheers
Cheers
