- Joined
- 29 Jan 2017
- Messages
- 3
- Reaction score
- 0
- Country
hi,
We moved into our new house 3 years ago and had problems with the heating from the start. The original issue was that upstairs got hot and it was 45 mins later before downstairs heated up. This was eventually fixed after it was discovered that there was only a single feed and return pipe coming off the upstairs feed and return loops to heat all the downstairs radiators. The solution was to upgrade the feed and return pipes going downstairs to 25mm and to split downstairs and upstairs into separate zones by taking the downstairs feed from a new output of a zone valve. All was good or so we thought!
Now the radiator in my sons bedroom heats up even though I have switched off the trv valve(I also swapped the valve from another radiator in case this was the problem), I know it's plumbed correctly as I can feel the pipe going to the trv is a lot hotter than the other end which is obviously the return..... I'm thinking that return hot water must be going into the radiator and heating it up, this is the radiator near where the single original feed was going downstairs if that matters? What I'm wondering is, would a non return valve at the return feed end of the radiator solve this issue?
