Hi all,
I have a radiator which i am trying to identify - i wonder if someone can help me with this...
The rad has no bleed valve - just two 15mm openings at either end. One at the top (left) and one at the bottom (right).
Is this rad designed for a particular application - can it be used for regular flow / return central heating systems. Can i add a bleed valve - i understand that some systems have them placed on the flow (input) pipe - is that correct.
Hope some one can enlighten me on this...
many thanks
Imirillo
many thanks
Imirillo
