    Dismiss Notice
Radiator is leaking at the tail piece part of valve
Discussion in 'Plumbing and Central Heating' started by New2DIYing, 21 Dec 2013.
  1. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Hi guys
    My radiator I just put up is leaking at the tail piece (please see pics below). Today I drained the radiator and ensured that both tail pieces were tightly screwed in to the extent they would not turn any further. I was hoping this would have sorted the issue as there was a bit of tightening to do.
    However I put the radiator back up and the leak is still there... How can I fix this? I am planning on trying again tomorrow but this time reapplying the PTFE tape or even using some plumbers mait?
    Any advice would be greatly appreciated.
    Thanks.
    PICS:
    [​IMG]
    [​IMG]
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    More likely not done enough turns with the ptfe need a good 10 turns.
  4. mogget
    mogget
    18 May 2008
    1,898
    Thanks Received:
    163
    Wiltshire
    Country:
    As an aside, you don't need to put ptfe on the thread of a compression fitting (other end of the rad valve). If it leaks after tightening, a little ptfe or jointing compound on the olive can help.
    You need more ptfe than you might think on radiator tails.
  5. Slugbabydotcom
    Slugbabydotcom
    10 Mar 2005
    3,512
    Thanks Received:
    86
    Middlesbrough
    Country:
    Sometimes the thread is faulty. Bad casting, impurities in the metal, seam cracks, welding faults and leaks running down from higher up are all situations I have encountered. So after trying more PTFE look into these possibilities.
  6. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Do you mean it needs more PTFE tape? i.e. around 10 wraps? Or not enough turns when tightening it?
    Thanks!
  7. Sponsored Links
  8. rego
    rego
    26 Jun 2005
    155
    Thanks Received:
    25
    Tyne and Wear
    Country:
    yes more ptfe. i always have 12 wraps
  9. rjm2k
    rjm2k
    30 Jan 2008
    2,125
    Thanks Received:
    163
    Yorkshire
    Country:
    At least 10 wraps of tape, I just changed the tail on one of mine and put more like 20 wraps on. No leak!
  10. Madrab
    Madrab
    4 Oct 2012
    7,839
    Thanks Received:
    2,200
    East Renfrewshire
    Country:
    Yep, loads of tape as everyone has mentioned. The threads inside the rad aren't usually as clean as the threads on the tails so needs lots of tape to take up the slack.
  11. mogget
    mogget
    18 May 2008
    1,898
    Thanks Received:
    163
    Wiltshire
    Country:
    Also, I don't think anyone has mentioned (can't be bothered to re-read), but you need to wrap the tape in the right direction - clockwise, looking with the end of the thread toward you.
    • Thanks Thanks x 1
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
