Radiator measles
31 Aug 2008
Kent
The radiator in my dining room was thick with about 10 layers of paint, the top two or three ordinary gloss which were bubbling and discolouring. So, I stripped it all off, with several applications of paint stripper and a lot of elbow grease.
The time finally came to repaint. I applied a coat of white primer and left it to dry. An hour later the whole radiator is covered with a dense rash of rusty coloured spots.
It looks awful. Where did I go wrong and what can I do?
sounds like you used an acylic/water based primer.
i would remove it and use an oil based metal primer or one of the all in one radiator enamels you can get
you're right, I did. I knew I should have gone for the all in one stuff! Thanks for the reply.
dont tell me, you "came up" with that one, or was it just a bit rash?
