I have a radiator that stays partially cold. The sides heat just fine, but the middle stays cold. The water guide bit of the bleed valve is broken on it, but I have bled it without it and air and water did come out but still no joy with the cold bit.
When bleeding the radiator the heating was off, is that correct?
What else can I try?
Would trying a cleaning solution help at all?
http://www.screwfix.com/prods/89458.../Sentinel-X400-Central-Heating-Sludge-Remover
The system is a combi boiler and it’s a standard radiator. The other radiators work fine.
