- Joined
- 19 Dec 2010
- Messages
- 12
- Reaction score
- 0
- Country
I had a new radiator fitted about 18 months ago, however when it was fitted a nail was put through one of the 15mm pipes which feeds the radiator, this was not discovered for some time. To fix the problem a length of 10mm pipe was inserted along the damaged 15mm pipe and then joined back up with the 15mm before it joined the radiator.
In essence I have both a 15mm and a 10mm pipe used as flow and return???.
The radiator is not as hot as the others in the house, i'm not sure whether it's to do with BTU's or could it be because of the 10mm pipe fix?.
Any suggestions...
Any suggestions...
