- Joined
- 4 Oct 2021
- Messages
- 17
- Reaction score
- 1
- Country
Hi, I live in a 4-bedroom detached house with 13 hot water radiators driven by an Ideal condensing boiler installed a couple of years ago.
Every radiator comes on uniformly hot when in operation except the radiator in my en-suite bathroom. This radiator is hot at the bottom and much cooler at the top. Typical symptoms of an airlock, right? So I bled the radiator. Some trapped air hissed out and the radiator was uniformly hot in operation again . But after a month or so the problem came back. I bleed the radiator again and everything is right again for a month then I have to bleed again.
This has been going on for some time. I think it was happening before the boiler was replaced but can't remember as I wasn't being proactive in bleeding radiators in those days
Can anyone suggest possible reasons why this airlock is continually coming back and whether fixing it is a suitable DIY job? Frankly if it expensive to diagnose or fix the problem then I'll just put up with it. Spending five minutes bleeding the radiator every month is not such an awful job. The problem does not happen with any other radiator in the house.
Any thoughts gratefully received
