Hi
I need to replace a radiator in my kitchen which is an old single panel type. I believe it's type 11 ?
I need to make sure that the new rad will fit on to the existing valve connections.
I have measured the width of the previous radiator at the widest part from each end of the valves which is 830mm and the height is 755mm.
Will this be a standard size radiator or may I have to re-plumb to suit a new one ? The nearest measurements I've seen for sale are 800Wx600H but how do I know if the valves will be the right distance apart for the pipes ?
Also are there any other considerations must I make when buying a new radiator to make sure it'll fit ?
Sorry for noob question and thanks for any help
Paul
Paul
