Radiator swap, remove floorboards
10 Jan 2010
London
Hello,
not sure if my question should be here or under Flooring, but here I go.
I have a spare Type22 radiator, which I want to swap out for this Type11 radiator. The Type 22 is a bit wider and requires about 4-5cm extra width on both sides. My question is:
- Should I just leave the floor alone, and install two elbow pieces to go out and up? Will ask a plumber to do the soldering.
- Should I cut open the floor boards and reroute from below with new holes through the floorboard? If so, is it sufficient to just remove the first floorboard, cutting somewhere along the joist?
See picture.
