PTFE tape is the last thing I would use nowadays.
Horrible stuff.
Horrible stuff.
Hemp and boss white
Well, the PTFE did the trick nicely. Wrapped it round at least 10 times. And also fitted the tails whilst the rad was still on the floor (as opposed to being mounted in situ on the wall) so that meant I could get some more torque through the spanner.
PTFE does what it says on the tin.
Its also an excellent method to use on compression joints if you want that perfect belt and braces approach.
Manufacturers will say their product needs no extra sealing materials added which is to be expected.
Some say a light lubricating oil can be applied which is a good idea.
PTFE on a compression joints fulfill's two purposes...
1 - Reduces friction (Thus less torque required for a tighter joint)
2 - Acts as a sealant (Thus preventing leaks)
Plumbers with the over inflated ego's say its not required and will argue the point until the cows come home.
But if you had 1000 28mm compression joints on a 10 bar system and Plumber A used ptfe and the plumber with the ego uses nothing as a manufacturer recommends then the guy with the inflated ego will have it busted when his 1000 joints are leaking like a sieve.
