    Dismiss Notice
Radiator valve leak
Discussion in 'Plumbing and Central Heating' started by lmsava, 29 May 2007.
  1. lmsava
    lmsava
    15 Aug 2006
    66
    Thanks Received:
    Country:
    Need a bit of advice. I removed a radiator to do some decorating and when I was reattaching it I over-tightened one of the nuts. Now the valve is leaking. The leak is coming from the place where the valve is connected to the copper pipe. It is leaking a fair bit. My guess is that the pressure seal is broken but I'm not sure. Can I repair this easily or is it time to call the plumber in?
  2. JohnD
    JohnD
    15 Nov 2005
    73,555
    Thanks Received:
    4,241
    Crossgates, Europe
    Country:
    Cook Islands
    not a difficult piece of plumbing. It can even be done without draining down the system, usually.
    Does yours have a Feed & Expansion Tank in the loft, or is the system filled with water using a filling loop at the boiler?
    Does the copper pipe comeup through the floor; and is it a concrete floor?
    If you can post a digital photo, that will save time.
  3. Sponsored Links
  4. lmsava
    lmsava
    15 Aug 2006
    66
    Thanks Received:
    Country:
    Thanks for the reply. I called a plumber in as on further inspection the valve wasn't the problem. Where the pipe meets the valve, the pipe had crushed so it needed replacing which involves a bit of soldering. Plumber was only £40 and took less than an hour and at least I know it's a good job.
    The system was drained anyway because of the leak.
  5. gas4you
    gas4you
    23 Feb 2007
    21,178
    Thanks Received:
    1,912
    Norfolk
    Country:
    Did you remember to add new inhibitor to the system when you filled up?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
