Hello everyone. We are renovating and extending a 1920's property (images attached). Ceilings, floors and plaster have been removed so 'straightforward' to repipe everything from the start. On the ground floor we are creating a large L-shaped kitchen/diner and we would like to go with wet UFH just for this part, and then radiators for the rest of the house. This is because kitchen/diner will have a properly insulated/screed floor and cavity/rockwool insulated walls and ceilings (albeit 3x
Velux windows and sliding doors) and we would like this to be tiled, whereas all other areas are suspended timber floors and floorboards.
Now based on some 'simple' maths, I would need about 4KW for the UFH and 11.5KW for the radiators. We will also have 2 showers and 1 bath/shower. Here are some of the questions I am troubled with and I would like your support:
1) I am concerned that UFH alone might not be enough to warm up the kitchen/diner. There is also a log burner in the room, so that might be a solution? Or should I throw in a radiator or two just in case?
2)What type and KW boiler would be advisable for CH/UFH/Hot Water (to connect all onto one boiler)? From asking around my impression is that a good storage combi would do the work and then separate/zone it for UFH with additional thermostat. I am trying to avoid adding cylinders.
3)Am I right in thinking that it's best to go for a 22mm main feed and then split this into individual 15mm branches serving 2-3 rads each (4KW max)? Would the UFH be on a 22mm or 15mm?
4) We have put in a new MDPE pipe from the meter as we replaced the lead pipes and the pressure and flow are very good. Having in mind that 2 showers might be used at the same time, please advise on boiler flow and other parameters necessary to have adequate flow and pressure to both showers. I presume if two showers are running, we are looking at about 28L/min?
Thank you very much in advance!
