Our thermostat for the central heating is the lounge and is set to 10 degrees ie I assume boiler shouldn't heat the central heating until temp drops below 10 degrees (Boiler also heats the hot water).
Problem is the upstairs en-suite radiator (next to the boiler housing) is red hot, switch this radiator off (via thermostat valve) but then rest of upstairs radiator are hot, switch them all off upstairs but then the radiator at bottom of landing is hot!!!!.
I know you guys will know what's going on so thanks in advance for any feedback.
Cheers
Pete.
Cheers
Pete.
