With my Potterton Promax Combi HE Plus A, the radiators downstairs don't heat up properly. Upstairs work quite well but when they are turned on the downstairs will not heat up at all. I have removed them and flushed them and also used a cleaner but this hasn't cured the problem.
With all radiators turned off except one downstairs and the locks shield turned up to maximum it still won't heat up properly.
The heating flow and the heating return seem OK and are both very hot to touch. The pump is also hot to touch and vibrates as if it is working OK.
Most of what I have read point to a problem with the pump. I removed the pump head the checked the impeller and it is spinning OK.
Any ideas would be appreciated. Could it still be the pump?
