The boiler is a Baxi Combi 133 HE Plus which is quite old now.
The problem is that when the thermostat calls for heat, the pump comes on and the boiler fires up as expected. The flow pipe gets really hot but after about 2 minutes the boiler stops firing and the pump continues to run. After a a few minutes of pumping cold water round the system the pump stops. A few minutes later the pump starts running and the boiler fires up. This cycle seems to repeat while the thermostat demands heat. The return pipe never gets warm.
I've tried adjusting the radiator temperature knob but it seems to make no difference.
There are no fault LEDs showing and I've tried turning the whole thing off and on again but to no avail!
The DHW works fine.
Any ideas please?
The DHW works fine.
Any ideas please?
