radiators
13 Apr 2008
London
I have tightened the nuts at each end of a rad, buy it still operates, frightened to tighten to much, am I doing something wrong.
It has a leak you see
Yes that too :lol:
I have a rad that leaks slowly, am going on holiday for a week, and want to stop water entering the rad. Do I tighten the nus or loosen. :oops:
I do realise that,I have a few days,
I have tightened them up but water still getting though, how much pressure can I apply without breaking something. :(
sounds like you valves are worn out and need replacing
so does your radiator
Summer's here now... an ideal time to turn off the boiler, drain down, and do that maintenance and flushing you've been thinking about. Fit TRVs and full-bore drain-off while you're at it. You can have a Magnaclean too if you like.
Not the answer you wanted :lol:
Where is the water leaking from?
If its from the radiator itself, or from the radiator side of the valves, turning it off won't stop the leak straight away. A dripping rad, although one that's turned off, can drip for a long time before all of the water has come out.
You may also need to drain the water from the radiator.
If your valves are turned off but the leak persists it could just be the water in the rad.
You mention 'at the join' but there are two 'joins' on each valve. One is on the radiator side, the other on the incoming pipework.
The best way to cure the problem is to replace the valves with quality (eg: Honeywell-Drayton-Danfoss-Pegler) units. To do this you need to drain the water out of the complete system, you will also need some PTFE tape, some rudimentary tools and practical nous.
If you are missing any of these things get a plumber in. There's no shortage of them around, the media have stirred a plumbing explosion. I expect your next door neighbour is one.
Get it done during working hours and pay less. Call a 24hr number and expect big bucks. :cry:
