radiators
19 Jul 2010
Coventry
Hi my all rads work in my house fine apart from two no need to bleed them i have done that and the pipe leading to then are not hot either?
worcester 28cdi. both the last two rads are cold and pipe work leading to them. the rest of rads are fine.
turn all other working rads off and see if the non-working ones work. Also check both valves and ensure they are open
Try it, if it doesn't work we'll come up with something else. If it does work then the problem is solved
