Rain Penetration Through External wall
15 Feb 2006
Manchester
Hello.
The wall in question is a solid fairfaced blockwork 215 thick, with 19mm 1:3 cement/sand render to the external face which has been painted with Snowcem paint. Rainwater is penetrating to the inside of the building.
I know little about render mixes, so firstly is a 1:3 mix classed as a weak mix or dense mix and is it porous or impermeable?
What mix would generally be suitable for a single brick solid wall and what remedial measures could you suggest?
I don't have a lot more info on the condition of the render at this stage.
any help appreciated!
Well MFC you say 3-1 render coat. Is this just one coat? If so the usual procedure is a scratch coat then a top coat. Sometimes on single block or brick we "scut" the wall first then scratch then float.....
Hi ya
Are you getting water running in at the bottom of the wall or damp patches on the wall?
is there earth against the external side of the wall?
There are a few things that can cause water /damp in the wall.
If you are going to Re-render the wall use a good water proofer in the mix
