Can you help? This is a new build. Builder hasn't been paid yet. I think the ridge tiles are laid the wrong way around. Can you confirm or am i wrong. The ones on all the other hipped ridges run the other way.
So am I right in thinking that this may cause problems in future and needs to be rectified. To my limited opinion this will allow water in. Am I right?Thanks for your input.
It's a dry ridges system, so the membrane underneath should stop any leaks that get through. If you get him to redo it, make sure he renews the membrane underneath.
