Fitted plasterboards, using screws 15 mm apart, on a timber frame. Only done a few so far.
Left 3mm gap in between each board. Screws 10 - 15mm from edge.
Problem is, some of the edges are raised, by about 1mm. This makes it impossible to tape and join. No idea what is causing this.
The timber beams are flat.
What effect will it have to just sand before taping and adding joint plaster? I guess the white paper and brown paper will come off. How will this effect the quality later on?[/quote]
