I have removed our kitchen and we will be using this room as a living room / dinning area. The room was tiled after the kitchen was fitted and now the area where the units were is 10mm or so lower than the tiled area.
I am planning on leaving the tiles in place and raise the lower section up to the tiled level. What would be best to use? Self levelling compound or a sand cement mix will do? If sand cement mix be better, what ratio of sand to cement should be used?
