Wifey has persuaded me to get her a Range cooker, and a double oven in new kitchen.(why when we only get chips and egg
) Always had gas so I need to run a cable from one side of the kitchen(range) to the other (double oven) and then to CU. Do i need to run seperate cables to CU. (range rated at 2.5KW, double oven 4.5KW) or can i run both to heavy duty junction box then to CU?? would you use 6mm cable or 10mm??
( I do have room in the CU for seperate cables)
