I'm sure I'm just not searching for the right thing, but I'm struggling to find information on this online.
Is it possible to extend the range of the mesh using a wired extension from the main unit?
Context is:
I have a Texecom Ricochet Premier Elite 64W with the system split into two Area's. One serving the main house and one serving an outbuilding. The outbuilding PIRs work ok most of the time, but the wireless keypad in particular is extremely sluggish. For example it will take around 3 minutes to register a pin to deactivate an alarm. I assume this is a mixture of the multiple external walls plus I suspect interference (I read somewhere heatmiser thermostats can interfere).
I'm willing to run cable to the outbuilding, but I do want to keep it on the same main panel as it's own area. Can you run an expander or something wired from the main unit to extend the range? Or any other way of doing it?
Thanks for your help
Context is:
