Hi. Can anyone help. The larger of the 2 electric ovens has stopped getting hot. It tripped the breaker. The right oven still works and gets hot to the right temperature whereas the main oven does not. Any suggestions as to the fault?
You need to check the element, once the power is disconnected. You may even feel a "blow out" or break; I suspect the element is allowing power to earth. POWER OFF.
