I've been hearing noises for the past several weeks and finally suspect the rats are getting in via the soil waste stack as I could hear the noise coming from the base of the stack.
Pics attached
I removed the floorboards and at the base of the stack I could see droppings and a pungent smell!
Looking at the base of the stack I can't see any obvious signs of entry but alarmingly someone has caked the area using expanding foam!
I suspect there must be a hole somewhere near the stack and allowing the rats to get in.
To try and remedy this and hopefully prevent rats from getting in, I'm planning on removing all the expanding foam and use a mix of ballast/cement to box in/cover all the area up until the neck of the waste pipe
Would this be the best approach?
Pics attached
