Rattling noise around rear wheel
9 Jun 2014
Yorkshire
I am pretty certain something is loose on a rear wheel. I get this dull rattle sound if the van moves over speed bumps etc. is it likely to be a swing arm ?
Grab the exhaust tailpipe Trevor and yank it to and fro to see if you can get the sound.
Which van is it?
John :)
citroen berlingo longer wheel base. 2015. I did have a new exhaust fitted last summer and under carriage as a rock scrapped the whole bottom of the van.
Brake back plate loose?
The type of noise can sometimes provide a clue, is it a light tinny rattle or something deeper and more substantial?
Can you look at the back of the van, and see if the rear wheels are showing any negative camber, i.e in at the top, sloping outwards at the bottom?
Does the noise sound more like a boing ( spring noise) when you go over a bump?
John :)
