RavenHeat CSI 120T Low NOX Boiler
3 Nov 2010
Worcestershire
I have just had the above boiler fitted and is working well except that when I fit the front cover the unit becomes like an amplifier and makes a terrible drumming noise sounds like Portland Bill and can be heard all over the house usually when the fan is working (exhausting).
Currently it is running without the front cover fitted.
The installer seems not to be able to identify the cause and a Ravenheat engineer is due in a couple of days to look at it.
I have tried fitting foam between front panel and sides etc to no avail.
Any ideas what may be causing this, and a possible solution would be greatly appreciated. :?:
You have a fault with your air /gas mix,
more than likely something wrong with your flue(if noise only occurs with case on)
do you have a long or short flue? vertical or staight out?
You are highly recommend not to use ur boiler with the case off!! - do so at ur own risk
Thank you for your suggestion.
The flu is short and fitted horizontally.
I am aware that front should be fitted, very aware and only me at home.
This is something I will leave for the engineer due tomorrow
please tell us your findings i had a similar problem.replaced boiler in the end as could not find fault
Who replaced the boiler for you , Ravenheap under warranty ?? Interested ??
No boiler had numerous problems from day one.Electrics at first then over heat stat. banging on got worse just took it out was that peed off in a rental property so fitted a new ideal with 5 year warranty sweet as a nut compared to the ravenheap..
But the Ravenheap comes with a 3 year warranty , why did u not complain to Lewis , or get them in ?? to sort it ?? how much did you pay for the heap ??
Not one of them Logics was it ?? from the manufacturer of such Turkeys as the Icos Isar & Response
Hi there I was looking at your issue that you had with your Ravenheat csi120t and was interested in the outcome as mine has just started doing the same thing. I noticed that one of the replies you had thought that it may be the air/gas mixture, or the flue.
Did you manage to resolve the issue and if so what was the outcome please :?:
