I am hoping someone can help me as i am at the end of my patience. Our boiler we had before conked out on Sunday 6th May, so we brought a new one. This was fitted on thursday 10th May by a Corgi bloke and it all worked fine. Friday the water was hot and so was the rads. Then on Saturday the water started running hot and cold and had to be run a low pressure to stay warm (not hot) then the rads decided not to heat up we have looked at the pipes and discovered a small dripping leak from one of the valves and now when the boiler is turned on by the thermostat it lights up, sounds ike air is in the boiler, cuts out and bangs then repeats we are fed up with this now as it is brand new can anyone help?
