Just had a look at my mothers boiler as she cannot get any hot water.
Heating turned off & when demand for hot water the boiler will not fire as the plunger on the 3 way valve is not moving to contact the microswitch. If i press the microswitch with a screwdriver the boiler fires but the CH pipes get hot.
I am only able to get hot (ish) water if the heating is running.
Divertor valve u\s you think? Just about to order one but thought i would check here first.
The divertor was renewed under warranty in 2006.
Thanks for any input.
