I have a Ravenheat RSF820/20T combination boiler which has stopped firing up on both hot water and central heating demands.
This happened before many years ago and in this instance it was a small blockage in the pipe leading from the main fan unit to a microswitch which clicks in when high speed fan mode is active.
The system pressure is 1 bar, the pilot light is on and burning correctly so my thoughts are turning to possible thermocouple failure.
I'm fairly sure it's the thermocouple as when you blow out the pilot light and wait for it to cool, normally after a minute or so you hear a loud click as the auto gas cut off kicks in. This I can no longer hear.
I have two questions:
First is there anything else I could check which I haven't mentioned and second is there a way to actually check the thermocouple isn't functioning using a volt meter or other device.
I am fairly adept with the boiler and have replaced many parts in the past. Where my skill is lacking is in the diagnosis of the problem.
My thanks in advance for any replies.
