Apologies for the lack of technical detail here. My Ravenheat combi 84ET failed to supply heat via central heating yesterday. I switched the boiler off at the mains then switched it back on after a couple of minutes and it appeared to be working ok - supply available through radiators. However, it cut off after only a few minutes - no operational noises (fans, burners etc). I double checked the fault symptoms by reseting it again and the same fault conditions apply. Would anyone be able to give me any pointers as to possible causes for this.
Cheers
Scott A
Cheers
Scott A
